Gel Seal II Question
"Need to know if I have enough
"Need to know if I have enough of this product to properly seal both halves of the engine block together. The parts just arrived and the tube of Gel Seal II is a little red tube with "Net .20FL OZ 6ml" (P/N 324073) will this be enough for the seal between the engine block of a 1990 3cyl 70HP Evinrude, or should I order a second one before proceeding? Your experience is appreciated. Jeff"
"Well now, you just need a bea
"Well now, you just need a bead 1/16" in diameter. 6 ml is likely enuff to do 2 or 3 motors."
