Geen wire 1998 200Hp Johnson
nicknack2
"any body knows where these tw
"any body knows where these two wires go? what they are for? and if they hook up to each other??
url]
url]
"it appears,..to be your tnt w
"it appears,..to be your tnt wire,for the sw on eng lower cowling pan...is it working?"
"on my engine, that plugs into
"on my engine, that plugs into the side cowling for the tilt button on the side. but i dont think it is the same for you."
the tilt and trim are working
the tilt and trim are working on both switches at the remote and at the right side of the motor...
"ok........see if u have a gre
"ok........see if u have a green wire,..coming from tnt SENDER (for gauge)..left st bracket....that would be guess # 2...if so,it would be a ground."
JWB where is the TNT sender lo
JWB where is the TNT sender located???(left st bracket???) I do not have a tnt gage installed....
"bingo....dont give it another
"bingo....dont give it another thought...that grn,runs fr sender unit gr ocation,into the tnt elect box i believe.....not a prob..
-sender,is the lil blk thing,on port st bracket,look UNDER there..has a 4 " or so,arm on it..in any case..dont worry about it,since u have no gauge."
