I'm rehabbing this old Crossflow. Took gearcase apart, and found the pinion gear chewed up (5 teeth, all together, chewed up). I don't understand how, but the other gears look virtually unscathed. I acquired the motor this way, so I have no idea what happened. Any thoughts on what could cause this? Also, I located another OMC v4 hydro assist gearcase which I took apart... parts are in excellent shape. Only problem is, this gear set is 13:26 as opposed to 13:25 in the original gearcase. And, of course, in typical geezer fashion, I've got the parts from both gearcases jumbled together (don't ask). Other than changing my gear ratio from 1.92 to 2.0 should this affect anything else? Might I have issues now that I've got the parts mixed together? (I have the gears sorted out). BTW, I pulled the pumps from both cases. The screen was totally clogged on the damaged case, the other is clean as a whistle. I appreciate any input. Geezer.
