Hi there, I have an early 80's seamaster 21, with an enfield leg. I'm not very good at the technical terms of engine parts but I will do my best to explain them. Basically the boat doesn't go into gear when using throttle lever however when I push it into gear manually on the drive leg, it goes into gear and I get movement but as soon as I go into reverse with the throttle lever it pops out of gear and have to manually push it into gear again in order to get movement. The guy who had a look at it reckons its the enfield drive leg thats worn out, if it is that where would I be able to buy one second hand? as I know they dont make them anymore. Im not sure about he model of the leg, would any old enfield leg fit?
Also what other potential problems could it be?
