OverHulled
Hi All,
New to site, and would like to ask some advice with an issue.
Engine: 90hp 4 Stroke ELPT
Year:2000
The issue started with no water from pee hole, on removal of lower leg and water pump cover i discovered the water pump base plate corroded, so decided to replaced the complete water pump setup which included water pump base plate and the seal that fits under the water pump base plate, new gaskets, wear plate, impeller and water pump cover, took it for a 20km test run this morning in fresh water and had a good solid stream from pee hole, when home noticed white substance coming from the water inlet, when the motor was in the down position drained lower gearbox and white gear oil came out.
The manual page is confusing and it highlights seals lips facing up and seal lips facing down on base plate, there is no recess for a seal on the top of the water pump base plate and none on the original removed. is there an additional one below on the drive shaft.
Any help appreciated.
Cheers.
Year:2000
Cheers.
