"I have a 1995 larson with a m
"I have a 1995 larson with a mercruiser with the 5.7 chev block. I've been having to fill the lower unit revoir occasionally and noticed the fluid in the bilge. I took it in last October to be repaired and was told it would be done in mid November and it sat in their yard full of snow all winter, which had me boiling to say the least. I called this spring and was told they replaced the valve cover gaskets and pressure tested the lower unit and it was ok.
At this point I just want to get the boat and go fishing this weekend, but I'm pretty sure it will still have a leak somewhere because it did before and they didn't change anything.
I've read posts about the hoses possibly leaking or mid seals leaking. Where does the grease go.....it leaves the resevoir via the hose and goes where. I've looked with a light but it's hard to see. They probably did test the lower unit and found it to be ok but with grease in the bilge it has to be leaking upstream somewhere. I had the bellows and bearing replaced two years ago.
Thanks - Dan"
Thanks - Dan"
