Gear lube leaking
09dragon800sp
I have a 1989 Johnson 90hp outboard. It's been in the garage all with the motor trimmed down. Yesterday I moved the boat about halfway out of the garage and noticed after about an hour there was about 2 cap full's of gear lube that had leaked out from around the prop. Removed the prop and everything looks ok. No fishing line or debris back there. I cleaned up the gear lube that dripped out and no more has leaked. Any thoughts or should I not worrie.
Is it really black oil? Most likely that's just unburned oil from your exhaust. Gear oil and a fill pump are cheap. drain the lower unit into a pan and look for water and metal shavings. If all is good, refill with fresh oil and go boating.
KJ
