crownline204
Hello. I have a 2005 Crownline with 4.3 alpha 1. I winterized it and found no water in the gear lube. Now after winter I notice gear lube leaking out of a weep hole on the upper right (starboard) side. The hole is toward the front of the drive. I also noticed the lube resivoir is pretty low but not empty, still about 3/4 of an inch of lube. I don't understand why it is leaking. I had no problems last year at all and as I said there is no water in the lower unit. The impeller was not replaced nor was any work on the lower unit performed. Please help. Spring is here and it is about time to go boating. Thanks, Ray
