Gear case wont drop
toxin
"hi again
i am having troubl
"hi again
i am having trouble dropping the lower gear case to access the water pump, i did turn the prop slightly and doing that did make the case drop a little more however its still not dropped enough to access the pump. any idea guys?"
"The shift rod connects to the
"The shift rod connects to the linkage under the carb. You didn't by chance forget to remove the pin or screw?
If you can post more info on your motor, someone can probably post more detailed information.
D"
Remove the starter motor for e
Remove the starter motor for easy access to the shift linkage pin.
