gear '66 Mercury 500
leanderbarrie
hi all
where can i find the front and reverse gear of an '66 Mercury 500?
is it connected with this bar??:
if this has nothing to do with the gears, then this is my next question, what is it for? :)
thanks for reading and helping
Regards Leander
yes i removed the motor, the gears have to get out.. but i can find it in the lower unit then? my idea is to remove n°1 from this image:
then i can remove the axle, where to gears are connected to, also when its out i can remove the waterpump.
do i am right or is there a big problem i'm looking over?
thank you for answering so fast.
regards Leander
What is the problem with the motor ?-------Yes you have to take #1 off and take it all apart to work on the gears.----I would first test the shift function by turning the shift shaft on # 1 assembly with a vice-grip.
there is isnt really a problem wit hthe motor. but there is coming an electro motor in stead of an gas motor. but i have to get the gears out and also the waterpump.
hi again, i figured out everything about the previous talks, but i was wondering, what can i do to 'remove' the gears? the problem is that when it is in a gear, it doesnt turn the other side ( like it should) but i need to get it fixed, so that the prop will allways turn the side my axle turns. (sorry if my english is bad, technical english is pretty difficult) so, i need to get the axle fixed to the prop, and if its possible to get the ratio of 2:1 to 1:1 or something, would be awesome.
thanks for helping me so far, and thanks for reading.
Regards Leander
