PentaParker
I have a pretty basic Volvo penta gauge set from the late 90s. A rectangle of black plastic that has two fuses built-in at the top and also a light switch that illuminates all the gauges.
Keep in mind that I recently pulled my engine, and reinstalled it. During that time I redid the grounding studs at the back of the engine and put all the grounding wires on the studs with stainless nuts.
On random occasions, when I hit the light switch on the dash it will kill the motor and all the gauges will turn off. It’s almost the identical effect of what happens when you pull one of the fuses out of the panel. Sometimes it will do it five or six times in a row, then other times the lights will come on behind the gauges.
I’m hoping somebody might chime in and tell me it’s likely a defective switch. I thought basic switches just form a circuit and I’m having a hard time understanding what could go wrong in a switch that creates such a problem that everything wants to shut down.
Wondering if this is likely a faulty switch or more than likely something to do with the new grounds that I reinstalled. The two grounding studs were on the bell housing on the back of a 5.7 L gas Volvo penta.
