Kevin,
This boat was purchased with the hot foot already installed. This weekend I will check and test as you have indicated. At what RPM do you consider a high idle?
If faulty, are the reeds something that I can install or should it be left to a professional?
Agreed. The OEM reeds are extremely durable. The OEM reeds on my '79 Evinrude 140 are in fantastic condition and I have no doubt they'll last indefinitely. The only reason I suggested the OP investigate integrity of the reeds is because many in the go-fast crowd are convinced that non-metallic reeds are a necessary upgrade for a performance bass boat. The existence of the Hot-Foot throttle and the symptoms described by the OP made me wonder if someone possibly installed aftermarket reeds in this engine as a performance upgrade and that one or more petals is failing.Reeds on the Johnson / Evinrude V-4 motors rarely fail.
