"I have a double line gas tank
"I have a double line gas tank the connector that hooks to motor leaks on fuel side I have tried to put new o rings in several times but still leaks I have right o rings they came in rebuild kit for the top of tank, It seems that the brass rod so to speak on inside of connector that seats against o ring does not come up as far as the air side I measured it/ can you take the brass insert out and clean it or is it possible to take connector apart to inspect and clean I would like to be able to fix it as a new one is quite expensive"
