"Its a 1150 115hp 1977 merc ou
"Its a 1150 115hp 1977 merc outboard all the fuel plumbing from the gas tanks to input on motor are new today I started motor and it ran good but at idol 25 sec in it would want to stall I pumped the fuel bulb and the motor ran great( came back alive).also when i first started i noticed that fuel would come out of the built in screen/cover on fuel pump when priming bulb was pumped was leaking gas bad. the only gas plumbing I did not make new was imput line to fuel pump and out put line to top carb( or first carb i think top one)I did rebuild the fuel pump with diaphram kit 2 times maybe Im doing it wrong check out this noise at WOT conditions on water like glass http://s293.photobucket.com/albums/mm67/prairiedog700/?action=view¤t=06280 81349.flv fuel or electrical problem thank you so very much....Anthony"
