"If you have a magnetic type s
"If you have a magnetic type sender ( a plastic module that can be removed without removing the sending unit from the tank) then it could be very possible that it just flipped out.
If it is that type remove it and reinstall it and see if it works correctly.
Most sending units are one piece units and the sender is nothing more than a variable resistor. ~ 80 to 240 ohms... The magnetic types also have the same resistance but use a encapsulated module that is easily replaceable.
The only polarity sensitivity is sending unit sender to S termial on guage, ground to good ground. Wire color should be PINK for sender and BLACK to ground."
