knuckle47
Advanced Contributor
"This may be confusing but I w
"This may be confusing but I will try to explain it so everyone else might have an idea about the problem.
Having V-drives, my manifolds and elbows are reverse mounted. The OLD manifold assembly has a 1" wide water adapter between the manifold and the elbows. Every diagram I can find for these engines does NOT show this assembly. It shows the flow diagram going from the elbow to the back of the heat exchanger. Am I supposed to eliminate this adapter and just go from the top of the elbow to the heat exchanger? I did find on page 63 of the TECM 547 manual, an FWC kit #22667 BUT, that is the only description.
I did not repower this vessel so I am not too sure what the original installer had in mind."
