Hope I do not get beat up to bad on this thread.I know this subject has been brought up many times and I found plenty of info on it, but not anything on this question..Acouple of years ago I converted my 20hp(J20CRCOS) to 25hp by changing out the intake and it has been running fine.Last year I bought a 30hp(E30RCCE) very cheap for a parts motor.I know the intake on the 30hp has more area on the reed side compared to the 25hp.I wanted to experiment just for my own knowledge to see if just putting the nice clean 30hp carb. on the 25hp intake would work.Timing was stamped at 30* BDC on both motors.Set link and sync and set idle /low speed screw up and hit the water.Got the motor started easily and it idled just like the 25hp carb and thought it would be good to go.Had boat on trailer backed in while setting the idle, then tried to go for a run.Everything seemed great until I tried going from about 3/4 to full throttle and it fell on it's face.Did not stall just bogged way down like it wasn't getting gas or too much air.Not sure? and it did this repeatily.Would "Not" changing out that intake cause this.?Just wanted an opinion on this.I did see the CDI has a different # also than the 20hp.Was not sure if that was my isue either?Next move would be to swap the intakes and or the CDI and try again.
