I bought this 1978 Glastron with Mercury 80hp model 800 Thunderbolt 2 stroke 4cyl Ser#500I9751 but soon had running & starting problems. I've replaced/redone all necessary CDI stator trigger rectifier coils starter & solenoid correct plugs wires switch box carb & fuel pump kits fuel lines prime bulb everything! H2o pump ok compression 130#ea But...now at startup the MercControl choke lever must be up and motor runs Only Full Throttle. Putting the lever down does not lower RPM, I can only lower it by hand moving the motor port side vertical Throttle Arm & Spark Arm & go turn off the ignition. There's several adjusting screws, Throttle Actuator Cam, Secondary Pickup and so on?
Question: Can anyone please help? I Called Mercury but they're no help, answering from home eating donuts & my SELOC manual has become like my only source since Sacramento Area Marine Repair shops are forever to busy it seems
Regards,
Stephen
Regards,
Stephen
