So I bought this beat up Lyman boat last year( see "more issues" thread and others) and both tanks read empty. It has the electric senders that read resistance as the sender floats up and down. I took one off to see if the float sunk. It didn't. The resistance shows 240-20 ohms as I move the float up and down. Resistance at the gauge reads 412 Therefore empty. The wiring is old and I think I'm reading 412 ohms because the wire to the tank is corroded. Does that make sense? I will replace the wires tonight because it is easy to do. I guess it could be the gauge as well but untill I get between 20-240 ohms at the gauge I'll assume bad wire.
