Fuel pump
ringneck
Hello - I have a 1980 4.5 hp e
Hello - I have a 1980 4.5 hp evinrude (E5RLCSS) with an internal tank that needs a new fuel pump. The fuel pump that it calls for is # 388685 which I can find for around $80. Does anyone know if the fuel pump made by Sierra 18-7350 (around $40) would work for this motor? I really hate to pay $80 for a pump. Thanks
How long has it been since you
How long has it been since you used the motor last? the reason I ask is that the diaphrams can dry out and then they become very stiff if they have been setting dry for some time.
The issue will be whether or n
The issue will be whether or not it will fit in the space provided. Also when mounted it can not bind up on cowling. I use it's cousin the 18-7351 on 18HP Johnson motors with no problem.
Bill
"sierra fuel pumps,are an exce
"sierra fuel pumps,are an excellent choice....i have inst ..many.....but,as above,make sure of the application.."
"I'm pretty sure that it w
"I'm pretty sure that it will fit in the space provided and will not be an issue with the cowling. Not knowing much about pumps, I am more concerned that the pump may oversized in performance since the Sierra pump is for 6 - 15 hp motors."
The float regulates the fuel l
The float regulates the fuel level in the bowl. I can't see why it would work for you.
Bill
"To clarify: Since the carb fl
"To clarify: Since the carb float regulates the amount of fuel in the bowl, the "size" of the pump shouldn't be an issue(as long as it fits in the space provided)?"
I meant to say "I can'
I meant to say "I can't see why it wouldn't work for you."
Fuel pump 388685 is rated for 4HP up to a 25hp motor. That being the case the 18-7350 will work fine as it is rated for 6HP up to 15HP. No big deal there.
Bill
"hello Brad,
According to t
"hello Brad,
According to the omc number you gave their is no sierra to match it.
I would hate to see you spend 40 twice if you want I can look it up from your model number"
