"Yesterday I installed the Per
"Yesterday I installed the Pertronix ignition kit as suggested in this posting:
http://www.marineengine.com/discus/messages/12486/283242.shtml
It went really well and the engine was running fine, but just as I was finished adjusting the timing the engine died and would not restart. I still had spark (the timing light was still hooked up and it was flashing.)
I suspected a fuel problem. Getting my head down in the bilges I looked at the sight-glass next to the fuel pump and it appears to have really old gas in it, but it's so dirty that I'm not sure. By that time it was getting dark and I had a headache so I just walked away.
But first I was looking in the book and reading about the double-diaphragm fuel pump. Apparently the sight glass goes between the two diaphragms and indicates when the first diaphragm has ruptured. As I understand it, the second diaphragm is there to keep the engine running if the first one ruptures.
So if the gas in the sight glass is really old, that would suggest that the first diaphragm ruptured long ago, so maybe the second one has just ruptured?
But it gets more confusing because I compared the photo in the book to the fuel pump on my engine and I only see a single diaphragm "sandwich" layer. My engine is a 1976 120HP Mercruiser. Did they use the double diaphragm pumps that long ago? If so, maybe someone replaced it with an automotive pump sometime in the past.
I suppose I will replace the pump. If the old engines had only single diaphragm pumps can I still replace it with a dual-diaphragm pump from a newer engine?
Or should I just cap off the fuel pump hole and install an electric pump? Are they reliable?
Thanks,
--Brian"
Thanks,
--Brian"
