"Hello board,
I have a proble
"Hello board,
I have a problem, maybe someone can help.
2002 chaparral ,5.7 GI 280 h.p. multiport EFI.
Last week on the lake, the boat had a intermitten loss of power issue. for the most part it happened on the top end. several times it did not quite have enough power to get on plane. usually if i shut the motor off for several seconds it would fire up and take off like normal.
At the end of the weekend while retrieving the boat, I noticed the fuel pump was making a low whining sound.
So after we got back I changed the fuel filter and did a fuel pressure test. The high pressure was at 80psi and the low pump was 5psi. All the while I could still hear the low whining sound.
Do those pressures sound normal ? The last thing I want to do is spend $750 for a new pump if its working normal. Any ideas ?
Thanks,Jeff"
I have a proble
"Hello board,
Thanks,Jeff"
