"I have a 1974 CC with a 409 C
"I have a 1974 CC with a 409 Chevy, the engine is 1964 vintage rebuilt though. I put her in the water the other day. She has been running on land for the last 2 months without issue. Got out in the river after about 5 minutes at half throttle and she died. I tuned it up while it was on land last month points, plugs, condenser, rotor, cap, wires, and new filter/separator. She will run for about 5-8 minutes at about 2500 rpms then die definitly starving for gas. I had a feeling it was fuel related although the tank was full all winter and I put stablizer in it. I switched the fuel hose from the inboard tank and stuck it in a 5 gal. can of fresh gas and she ran for over 30 minutes at 2500 rpm without issue. If I connect up the tank she will only go about 5 -8 min. I left the cap off the tank and there was no difference. I removed the check valve from the line to eliminate it as a issue. I put a couple of bottles of dry gas in too. I put a vacuum gauge on the line running to the tank it pulls about 2-5 mmhg then slowly goes up to 10mmhg and then dies. I'm thinking there must be something in the tank. I made sure the shutoff valve was clean and pulled the tube out of the tank and it was clean. I'm getting ready to pull the tank but it's almost full and it's going to be a pain. Anybody have any ideas?"
