fuel problems i think
mike garrett
have a 92 omc cobra 5.0 when at 2000 to 2500 rpms runs fine then it will cut out a bit and then i slow down and it clears and off it goes changed fuel seperator filter seemed better then did it again any thoughts on what could be going on also changed plugs
quadrajet?
a lot of marine qjets like to develop a little hesitation at mid throttle accel. -try to get you to kiss the windshield.
They go lean. There is a spring that delays the opening of the secondary air valves that can "fix" it.
However it could also be the secondary metering rods or a number of other issues in the carb.
