Hey all- I've got an '02 70hp two-stroke Tohatsu. It's in great shape all around other than the fact that last summer, after running more or less fine the first time out, it subsequently would not rev under load above roughly 4000 RPMs. After another day or two, it would hardly even run, and eventually stopped. At idle, it would rev fine as I recall, but couldn't, like I said, in gear. At the time, I thought it was due to the fact that we had a fiberglass tank, and hadn't used the boat in a month or so, and that perhaps the ethanol in the fuel finally ate away some of the resin, and it gummed up the fuel injectors or pump. The boat yard looked at it in the fall and fixed it (I assumed), and junked the fg tank in favor of two eyesore red plastic ones.
Fast forward to the present, first run out a couple weekends ago, wouldn't rev above 4,000, and it would stall at idle, which it had never done before. Next day, basically the same, except it did run higher for maybe half an hour. This past weekend, worked perfectly fine and ran up as high as I desired (I don't think I quite got up to the RPM limit), except for the idle problem. Then yesterday, other than the idle problem, worked fine. UNTIL, that is, I got into a little bit of chop and the engine had to fight against the waves, at which point it reverted back to the <4,000 RPM game, and even then it would kind of halt at 3,500 and slowly work it's way up to 4,000, at which point it hit a ceiling.
I lean toward thinking this is still a fuel problem, but we've got plastic tanks, a new external fuel filter, new external fuel lines, new plugs, and good gas. Supposedly, the problem was fixed. Any thoughts on what this could be or a remedy if you know? I have not tried priming the bulb while the motor struggles at 4,000 because I'm usually alone and can't reach it from the wheel (and I think I did try that last summer to no avail). Also, if it matters- we used to winterize it ourselves by emptying the fuel tank, running the engine dry, then spraying fogging oil into the cylinders and air intake and turning it over a few times; we would let the yard winterize it and get bottom oil changed, etc etc every couple of years.
