Thanks for the informationNote------That unit is NOT a pump.----It is an electric VALVE that opens when key is pushed in.-------That unit is used on motors from 9.9 to 300 HP.------Model # of your motor?-----I believe there is a nipple on the intake manifold for the second hose.
I was thinking about using a Y connector to tie in both lines but I am guessing that would put to much fuel into the carb.Thanks for the information
Motor is a J30ELSRE
Sorry primer valve??----What switch ?------The red lever on this simple primer valve is for manual operation of the valve.--If you have one wee hose going to the carburetor and one wee hose to intake manifold , then you are ready to go fishing.----Why did you replace this valve ?-----Part # of the primer valve you installed ?----This primer valve is factory replacement or something else ?
Thanks again I am going to reroute the fuel lines from the primer valve one side to the carb the other to the manifold like you saidA repair kit is available to repair leaks.-----And on some applications ( 25 / 35 HP 3 cylinder ) there was only one hose needed off this wonderful valve .----This valve was used on 9.9 to 300 HP motor from about 1980 to 2005 models.
