barefoot51
"fuel pump (tested on twin
"fuel pump (tested on twin-good) , fuel lines, fuel bulb. good. no restrictions 2 the carbs. carbs fill w/fuel holds tight bulb but isn't delivering any fuel @ all. dry! .runs while spraying either but not on it's own. you can't even force fuel by squeezing the bulb.the owner said he went through the carbs & can't remember if he turned certain passages off.I went through everything 2 the carbs...good. not 2 formilurized w/ suzuki carbs. plus no sm. once fuel enters the carbs & fills them thats it no delivery like all the needles r in the perminent closed position. he also said he overreved it, herd a pop do u think he may have broke a/some reed valves. I kinda think it has 2 do w/a vacume/pressure thing in the carbs not allowing the release of the float. nice guy like 2 help him out. thanks barefoot51"
