1984 70 hp Johnson, Original owner.
I have had all sorts of issues with this motor holding vacuum on the fuel lines. I find myself replacing the fuel adapters every year because the o-rings crack every season. Now, on to the problem...it holds suction while running but once the engine stops it loses pressure and I have to pump it back up to get gas in the line. I have installed new clamps, new fuel lines and a new primer bulb. I Tightened the fuel clamps on all the connections till my fingers bleed. Also, I made sure the carb assembly connections were tight.
Is there something I am missing here?
