A sticking anti-siphon valve can result in anywhere from low to no fuel pump pressure, and can lead to serious engine damage created as a result of lean fuel/air mixtures. Its purpose is to prevent the siphoning of fuel from the tank should a fuel line develop a leak at a point below the fuel level in the tank. Normally the valve is nothing more than a spring loaded check valve which must hold a column of 20 inches of water and open at 25 inches of water. The valve can be removed provided under 33 C.F.R Part 183 found here: (http://law.justia.com/cfr/title33/33-2.0.1.8.44.html#33:2.0.1.8.44.10) scroll down to 183.568, but state regulations should also be checked.Sticking anti siphon valve in gas line pick up tube ? What problems would that create, how is it suppose to work and can the valve be removed?
