R
Russ Holden
Guest
"Hi,
I own a 1987 Four Win
"Hi,
I own a 1987 Four Winns Liberator 211. I had an issue with the fuel gage not working at all. It was peged on empty. After removing the wires and reconnecting it started working again but when the ignition is turned off, it pegs itself to the full side and when the ignition is turned on again it reads about 1/2 full. I believe this is an accurate reading. My concern is that I can not remember if it is normal to peg on full with the ignition off. My question is should the fuel gage read empty or full when shut off?
Thank you.
Russ"
"Hi,
Thank you.
Russ"
