tuna_man
For a friend.
he just bought a navman fuel flow sensor. Looks like the same one common to many brands.
Were not sure if it will work on this engine.
Theres only one line coming from tank. Goes straight to filter/seperator.monted on engine.
Im thinking it will work on that line. (Except wont be filtered).
However there is a return line to the filter, from a diaphram switch attached to the fuel cooler?
So i understand on EFI donks there is usually a return line to the tank, this one does not, but does have a returrn to the filter sep , which actually may be a common area inside the filter to the inlet from the tank. Im strugglin to find the right words here, boy i wish i could a way to draw a picture on this android.
so where do we put a single flow sensor on a alpha 1 gen 2 SBC, with 2 barrell throttlebody injection?
(Only one fuel line at throttle body, which contradicts the diagram in his Clymer manual).
