"IN my Trojan F26 with a singl
"IN my Trojan F26 with a single 318 I have two fuel tanks. The starboard fuel line is 30" long and goes from the tank to a brass 'T' at the separator. The port fuel line is 94" long and runs from the tank to the same 'T'fitting. The shutoff valves are on the tanks. Using a mechanical fuel pump, would the fuel pump from both tanks evenly? If one tank ran out of fuel, would it pull from the other tank? There is not a balancing line between the two tanks. Seems to me it would pull from the one that offered the least resistant (closest, shortest) and if that ran dry, it couldn't pull from the other because air would be pulled in from the empty tank. Do you guys run one fuel valve open and one closed?"
