Fuel flow meters
luhrs_40
Need some info on fuel flow me
Need some info on fuel flow meters...what is the best for the money and what does it take to install them?? Luhrs 40 with 454s and raymarine e80 display gps
"Hello again Peter. I assume y
"Hello again Peter. I assume you have carbureted engines. I have the FloScan on mine. Works flawlessly, and it's way more accurate than the fuel tank gagues. Also, with gas at $4 a gallon it'll pay for itself as you can find your best economical cruising speed. Your Luhrs will probably cruise best at about 15kts but that's just a guess. Stu"
"Thanx again Stu, can u tell m
"Thanx again Stu, can u tell me what is involve to get them install? And Flowscan i heard they are not cheap They are in the 700.00 range if iam not mistaken"
You can go with the Lowrance L
You can go with the Lowrance LMF 400 guage ($160.00) that comes with 1 fuel flow meter and purchase an additional flow meter for about $55.00. Depending on the distance to the bridge you may need a NEMA network extention cable. If you have a chart plotter with NEMA network you could also interface with the LMF 400 and then install the fuel tank level sensor. Then you would have all the fuel / range data you could ever need on your boat.
Robert's suggestion sounds
Robert's suggestion sounds a lot less expensive than the floscan. I have the floscan and it was an easy install-a sensor in the fuel feed line. The floscan looks like a tachometer with the calibration in gph. It also has a totalizer. I like mine but they are a bit pricey. Stu
