Fuel filter
jeff6898
Does anyone know if a 1979 evi
Does anyone know if a 1979 evinrude 85hp haver a fuel filter? IF so where is it? I dont see one on mine. Also the bulb in the fuel line. DOes it effect fuel flow at all if bad or is it just used to pump the fuel if you need to?
Yes it does its a screen mesh
Yes it does its a screen mesh inside the fuel pump open it up and you will see it.
"the primer bulb has a check v
"the primer bulb has a check valve in each end, if one comes apart it can cause a restriction"
