kghost
Silver Medal Contributor
If the yellow tube was clogged then that is not good!!
That is designed to direct fuel to the carb if the pump diaphragm ruptures......... also this is a tell tale sign the pump is bad!!!!!!!!
I think you have found your problem.
When removing the pump from the block there should be NO fuel anywhere but in the pump and the steel lines. If fuel was in the pump cavity where the lever goes into the block then it was leaking past the diaphragm (s) and past the lever assembly because the plastic tube was blocked......
In an automotive setting there is no tube, there is a weep hole where the pump barbed fitting is for marine and the fuel would simply leak to the ground........Not the best idea but that is how it was done.
For marine, obviously they could not allow that to happen so they installed barbed fittings and a tube to the carb.
Do not waist anymore time. Purchase a brand new Mercruiser MARINE replacement fuel pump!!
