fuel dumping into oil pan
Richardbf1
i have a 140 hp i/l 4cyl mercruiser. I recently had my mechanic put in a new impeller to solve an overheating problem. i also had him rebuild the carb since the boat had been in storage for over a year. it now starts immediately but after just a minute or less a mix of fuel and oil is coming out of the air filter (flame arrester)? What could be causing this?
you sure it's fuel and not water and oil.
Take the hose off that goes from the carb to the breather hole in the valve cover.
Is the mix shooting out of there?
thank you for your reply. i removed the hose from the carb to the breather on the valve cover and yes the mixture is shooting out from there.
coming out of the flame arrestor may be the "Tell-Tale" hose from the fuel pump indicating a ruptured diaphram in the fuel pump. Without this clear Tygon hose the fuel would dump in the bilge and you would go BOOM.
the engine year is i beleive is 1988. as you suggested i checked he dip stick. it is very clear and reads about a quart over? i just changed oil and filter about a week before this occured and fluid level was right at full then. you may be right about the water and oil instad of fuel and oil. i can not smell gas on the dip stick. also when the mixture was coming out it was like a foaming liquid. i hope this helps. appreciate your help.
Ok pull the plugs and crank the motor over, got water shooting out the plugs?
If no, shoot some wd in the holes put the plugs back after looking at them. They all shiny clean like being steamed clean ?
Ok pull the t-stat housing clean off the block, and shine a light into the neck, i had a hole develop between the first pushrod hole and the water jacket in the wall directly opposite the hole you are shining the light thru.
Touch the wall with a screwdriver and see if it opening up a small hole, don't have to push it like a knife in a cheating wifes heart just touch it.
If a hole did open between the pushrod hole and the water jacket the head is toast.
Ok If there is no hole you need a new gasket for the t-stat housing but not yet leave it off.
Take the riser off, what that look like it a pile of rust in there ? Look down the exhaust tube see a flapper stuck in the hole way down ? Both could be reasons for a overheat.
But the riser could allow water to mix with the oil.
You already know you got to change the filter and the oil about 3 times to get rid of all the water.
So do one thing at a time in my order, if you get to the point that all is well then you can pull the head, to reinstall the head you will need a kit of gaskets fel-pro makes a good kit and i think ebay has one right now, it has mani, head ,riser, t-stat housing and more about 70 bucks.
You have to get to this right away you do not want water in the motor if it's fresh water, not so bad if it's saltwater you might be too late already.
thanks for your help. i have my work cut out for me. i will let you know how it comes out hopefully by next Wed. again i truly appreciate your time and advice
