Guys, been a while since I've posted a question. I've been tied up with multiple car issues all winter. I wanted to get your advise on some fuel dilution readings on my 454's. Some background. I rebuilt both of my carbs about 4 years ago, approx. 250 hours of use. I used the kit from Cliff Ruggles and sent them in for bench testing and adjustment.
They have been flawless since and I have literally not touched them since they were reinstalled. I've noticed that the oil on the port engine turns dark pretty quickly and so I sent out samples from each engine to Blackstone Labs. They said the fuel percentage on the engine in question is 3.8% and the other engine is .08%. The fuel pumps on both engines were replaced around the same time so that's lower on my list of suspects. They are looking for readings of less than 2%. I also notice that when I check the oil that it drips right off the dipstick. It looks "thin" but the viscosity is fine according to Blackstone.
My real question is..... do you think it's simply running too rich?. I changed the plugs and they were black/rich looking which I know is better than too lean. I just don't know how much "range" a mixture adjustment can make or if that fuel percentage is likely beyond just an adjustment.Starting/idling/power up are flawless both sides which is why I've left them alone. I pulled the fuel vent hose off at the pump to see if any fuel poured out (although this was after sitting all winter). Good, although I smell a little fuel. Both engines are carb'd 1988's with about 1,200 hours and don't burn any oil.
Any thoughts appreciated.
thanks
Bob
thanks
Bob
