hrlybuilder
"I have a 1985 Carver 3207 Aft
"I have a 1985 Carver 3207 Aft Cabin with twin Crusader 350's. I discovered a fuel delivery problem in the starboard motor so I immediately changed the screen at the carburetod and the fuel/water seperator. This did not solve the problem (still no fuel at the carb) si I decided to change the fuel pump. Upon removal and disassemble of the old pump, I found quite a bit of sandy crud blocking the screens. Even though the new Carter pump was exactly the same as the old one, it was VERY difficult to install. I even tried turning the engine slowly with a socket and breaker bar to find a "sweet spot" to accomodate the rocker arm, but it was still very difficult to get the bolts started and "walk" them in by tightening them slowly and alternately. After hooking everything back up the carb was still not getting fuel. I then used a brake bleeding hand pump to pull fuel from the tank (no blockages) to the inlet of the pump for priming and poured some fuel backward from the carb end but it did not help. A pressure check at the carb showed 0. I also rechecked all connections (gasoline pipe dope on all hard pipe joints) and everything seems tight. When I put starting fluid in the carb the engine fires up instantly but dies after the fluid burns up. Any advice would be much appreciated. Thank you."
