Fuel Control Cell Element
richie
"Crusader 2007 8.1 MPI 385HP
How difficult is it to replace the FCC element, anything tricky, advice???
My owners manual says >>Service to be performed by an authorized
Crusader Marine Engines dealer only<< Should I follow the manual and let a professional do it ?"
Open it up and replace it. Ea
Open it up and replace it. Easy job. I would fill the canister with as much fuel as you can because the fuel pump is in it and may have a problem picking up the prime. You could remove the inlet fuel line and fill it thru that. There may be a plug on the top of it but I'm not near my boat to check.
"Ted,
in other words it's
"Ted,
in other words it's covered under warranty and my dealer will do it free of charge."
I doubt that the dealer will d
I doubt that the dealer will do it free of charge. Changing the filter is a user maintenance thing not something covered under warranty
