Fuel and vro
scubadoo
I am setting up my motor but n
I am setting up my motor but not sure if the vro is working properly
It doesn't hurt to run 50:1 in the first tank (70 litre tank)then check the res to see if the oil drops
Am I right in that assumption?
Jeff there is a thread posted
Jeff there is a thread posted under "how do I know if my VRO pump is working" just below this one. May answer your question.
"Not sure what You mean by &#3
"Not sure what You mean by 'setting up', but fill it with 50L fuel and 1L oil . Then fill Your oil tank 1/2 full and make a mark. Fill another 1L and make a second mark. After You have run out the 50L of fuel, You should be about down to 1st mark on the oil tank."
