Fuel air mix 21
Hi I have an 1985 bayliner wit
Hi I have an 1985 bayliner with an volvo 2.1 I was wondering what is the fuel air screw 2 1/2 turns out ? Also is the timing 10 Deg BTDC @ 900 RPM ? Please Help Thank You
"The approximate setting of th
"The approximate setting of the idle mixture screw is 1-1/4 turns, but you will have to fine-tune it to make your engine run smooth.
The ignition timing is correct. In any case, consider downloading the manual for your engine from here to verify the settings:
http://www.volvo.com/volvopenta/global/en-gb/marineengines/operators_manual/
If it is a 2.1 liter engine with single carb, it will be an AQ120B or an AQ125A; if dual sidedraft carbs, it will be an AQ140A."
Just jumping in here for a que
Just jumping in here for a question that has me wanting an answer.I have seen a lot of discussions on all sorts of motors on this site for a long time.there doent seem to be a lot about my setup (AQ145A)Is this because it is a rare combination or is this motor not old enought to have the problems I see discuseed with all the other models.I see some discussion about AQ140's but rarely about AQ145A.any comments please.
"Stan, your engine has a B23 b
"Stan, your engine has a B23 block, but the majority of VP do have either B21 or B230. I think that your particular engine was made for a short period of time, so from that point of view it is a bit of a rarity. Nevertheless, the problems that your engine may experience are no different from the rest of the OHC VP engines."
