"I purchased a 2000 Searay 310
"I purchased a 2000 Searay 310 sudancer at the end of last boating season. I ran it only 5 hrs and before ti was time to pull if out of the water and winterize it. The engines (twin Mercruiser IO, 5.7 EFI, Bravo 3)are raw water cooled with 345 hrs on them. The boat was always moored in fresh water but traveled into salt water on occasion, always returning to fresh water for mooring. In my openion this kept the cooling systems welled flushed with fresh water. I now moved the boat to another marina down river and I'm getting ready to put it back into the water there (in salt water) for this boating season. Would it be advisible to install a fresh water cooling system using the kits that can be purchased (including heat exchnger etc.) before I start useing the boat exclusivly in Salt water. Would this create a problem by adding coolant in an engine block after raw water cooling use for 8 or more years now? How long should i expect the engines to hold up in the salt water comditiond with raw water cooling? I also thought of installing a "T" fitting and valves in the intake water line (coming from the outdrive to the raw water pump)and flushing with fresh water after each weekend use. is this a worthwhile option?
Dan"
Dan"
