johanwahlberg
Hi,
I ran my engine about 50 hrs or less last season. It worked perfectly fine, until the last 4-6 weeks when it started to almost stall in low rpms. It has always been a bit rough at idle up to a threshold rpm level at which it smoothens out and start spinning like a cat...
However, last weekend, I was about to change the plugs (as in a standard seasonal prep) and I had ordered the BUHW/L76V (Surface Gap, NGK heat range 12) as recommended by my service manual. I found the existing plugs were B8HS (regular gap, NGK heat range 8). I haven't had a chance to see the pistons conditions but the guy i bought it from said the compression was good.
Should I switch "back" to the recommended plug - BUHW? Can this be what's causing the almost-stalling?
See video of the stalling problem in my old post: http://www.marineengine.com/boat-fo...8542-70hp-Mariner-unstable-at-low-rpm-(Video)
