BatteryMan
Motor: 1974 model 110 Kiekhaefer 9.8HP Serial # 3486640
Motor was running fine then suddenly stalled out during a high-speed run. Had to keep the carb almost fully choked to keep it running. Took the carb apart, and found the plastic venturi loose inside the throat of the carb. I can't figure out how the venturi was originally attached inside the carb. I tried operating the outboard with the venturi removed, but the motor does not run unless 80% choked. I pulled the high speed nozzle out of the carb to see how the venturi and nozzle parts might have originally fit together, but the hole in the venturi fits loosely on the tip of the nozzle (maybe this is why it fell off in the first place). I have a replacement venturi on order hoping that a new one will fit more tightly. I think I can tell the orientation the venturi should have inside the carb throat.
My questions are:
1) how do you mount a replacement venturi?
2) does the venturi stay on with friction alone, or is loctite or some other adhesive required to keep it on the nozzle?
Thank you.
My questions are:
Thank you.
