Take the carb to your local small engine repair shop they should have everything it needs. Is that engine air cooled?
For the life of me i cannot figure out how to add a pic?
No sure which wire you are talking about. Can you please give alittle more detail. Do I have to run the wires to both points. pics if you can.Sorry got threads mixed up to add a kill circuit you need to run two wires through the points plate and attach the wires to each set of points with the condensers. Then you just wire them to a kill button on the lower cowl. Solder the connectors to the wires and add a rubber grommet where they go through the plate. Not hard to do just make sure the wires do not interfer with the spark advance and not rubbing on anything. That wire on the nottom of the plate is just a ground connecting the plate to the block.
What did you do to fix it?
