Hi I need some help for the synchronization of my Force 85HP motor.
I have the Seloc manual and have seen some videos but still I have some doubts.
First thing according to the manual is to check the throttle cam inscribed line alignment to the roller on the excentric screw. Doing this by removing the cam link from the throttle tower (sorry if I'm mixing some names, I don't have the manual infront of me), once aligned turn the excentric screw until it barely touches the cam.
After that I'm supposed to attach the cam link to the tower again, but that now changes the possition I left the cam before, is it supposed the cam line and roller remain aligned at that point?
Then according to Seloc I should verify that the Carburetors are opening and closing evenly with the link bar that is attached to the 3 carburetors, I noticed that the bottom carb was a little bit off, when making the adjustment there, the previous adjustment went off, so I guess like some videos I have seen this step had to be done before.
Next I should push the throttle tower to WOT stop and verify if carbs open completely, there comes more questions not explained in the manual or videos.
1. I assume I should disconect the throttle cable from the remote control in order to do this.
2. My carbs were not opening completely when pushed the throttle tower to WOT sop, I'm supposed to adjust this by making adjustments to the cam/tower link, when I got the carbs to open fully (making larger the link) when I got back to neutral the possition of the cam vs excentric was off again, is this adjustment done this way?
3. I found also that when pushing the remote control to WOT the cable was not moving enough to move the tower to WOT stop, is this adjustment made in the cables? in order to get the tower to move completely? I did that and then what I observed is that the tower now didn't returned fully to what we had as Idle stop.
Well too many questions to put here, I'm looking to see if there is any other good video or other thread that explains fully this procedure, the Seloc or other videos I have seen missed some of the things I have doubts.
Thank you
Thank you
