my 125 overheats has new water pump no clog in water tube removed t-stat even pulled powerhead replaced gasket between head and exhaust
i had it in the water to check if i was getting water to engine no spitting from exhaust but saw alarge air bubble around prop or water inlet could it be bad ehaust plate gaskets or plate i pulled exhaust cover found a little water in the area of the inlet to exhaust plate just lower left corner of cover had water also exhaust plate is warped should it be replaced along with gaskets
