bretcobrageek
I have a 1994 Bayliner with a Force 120. Last summer the hydraulic tilt/trim pump motor started making a loud screeching noise sometimes when in use. Kind of like what one might expect if the bearings were going out in an electric motor. I checked the fluid level and everything seemed fine. I had planned on doing something about it after the season, but you know how things go...
This summer we're finally getting some great weather and tried to get the boat out last night (after charging the battery and then replacing it), the tilt control just "clicks" the relays but the pump motor doesn't even try to turn. Nothing. After the noises last year I assume the motor has completely frozen up. I'd like to replace the motor, but I'm stuck on a few issues:
1. I cannot find any part number, model number or anything on the pump other than a warning sticker. Any ideas where to look or how to fiture it out? (see picture below)
2. I need to release the pressure in the tilt sytem so I can lift the motor so I can work on the pump. I see the reservoir access, but I don't think that releases the pressure. I've heard something about a screw to release the pressure, but there is no marking anywhere about such a useful thing. Is that the screw on the top do you think? (the one that is up on a 1/4" high lump to the left of center. The others look like they are holding the top in place)
3. can I replace just the motor or should I replace the pump at the same time? Any suggestions for sources?
4. Any other tips for the whole process? Any links to manuals or antying that would help with this?
Thanks for the help. -Bret
