P
pescador69
Guest
"Hey Joe
Joe so perfo
"Hey Joe
Joe so performed the piston test that you told me, the top piston is solid as a rock, but the lower piston has a slight inward movement. thier is no side play on either of them, tried the setting on the carburater but the top slow will only make like a 3/4 turn in total you asked me to give it 1 1/2 turns. thire were no pins or anathing stoping the needle from turning. so i left the setting as it was, can you tell me what is the correct gas oil mix for this motor? thank you"
Joe so perfo
"Hey Joe
