R
Ronald Selleck
Guest
" Hello Joe,
I have been purs
" Hello Joe,
I have been pursuing your theory that my '72 Johnson 50 hp will not shift in water because the green wire is grounding to the water. I found when I took the lower unit off that the 5/8" countersunk bolt just in front of the trim tab was missing and that there was no sealer on the exhaust housing and gearcase surfaces, in contrast to what the manual specifies. There was plenty of water in there where the shift connector wire runs above the lower unit. Water is not supposed to run freely in that area is it? Seems like it would take a really well sealed circuit to withstand that much water. Could this be the answer to my riddle of why it would shift on the flushette and not when submerged? If so, do I replace the wire and the bolt and seal it up to cure the problem? "
I have been purs
" Hello Joe,
